It is currently Thu May 07, 2026 5:51 am
Post new topic Reply to topic  [ 35 posts ]  Go to page 1, 2  Next
Post Posted: Tue Feb 02, 2010 4:53 pm
How do you tell the flywheels apart? I have 4 flywheels here I need to know what one is off a W/T 1.3
Does anyone know the size of each flywheel.
Oh and to add a twist one of these may be from a Gemini. :) Long story but i have a milk crate of flywheels and a mate needs one for a w/t 1.3
Oh and they are at my house I dont have them on me. So I cant look for numbers till I get home.
Post Posted: Tue Feb 02, 2010 5:42 pm
Early 1.3 plates are flat.
Late 1.3 has a 5-6mm recess for the clutch plate.
Post Posted: Tue Feb 02, 2010 7:56 pm
ok great thanks thats what I was thinking.
Post Posted: Wed Feb 03, 2010 4:44 am
WRONG
1.3 swift flywheels are flat
1.3 litre sierra flywheel has a 2.1 mm recess for the clutch plate throughout the whole 1.3 range
1 litre sierra the clutch plate area is 1.8 mm raised
Post Posted: Wed Feb 03, 2010 5:57 am
WRONG
There are two recesses in the flywheel... :roll:
The problem has already been solved but thanks anyway. :wink: :roll: :wink:
Post Posted: Wed Feb 03, 2010 12:49 pm
WRONG
WRONG
some 1.3 sierras have a flat flywheel and use the swift clutch, I owned one
Post Posted: Wed Feb 03, 2010 12:57 pm
And on a related matter, aren't there 2 versions of clutch plate? 20 and 22 spline comes to mind?
Might be handy to mention if someone comes across this thread in a search.
Vehicle: '92 Sierra
Post Posted: Wed Feb 03, 2010 1:47 pm
Yep theres 2 but can't remember the spline count. I'm pretty sure the later were 22 and the earlier were 20 like you said or maybe 19??? I also screwed up once where I put an earlier clutch onto one of the stepped (recessed) fly wheels. As a result the car would drive but would slip constantly.
Vehicle: 95 Sierra Soft top
Post Posted: Wed Feb 03, 2010 3:57 pm
OK sorry to go of course just that lil but will a gti flywheel fit a 95 sierra ??
Post Posted: Wed Feb 03, 2010 7:38 pm
Both clutch packs will bolt up to both flywheels. the difference is in the trans input shaft.
Post Posted: Wed Feb 03, 2010 7:44 pm
It should but with it being lighter it will take away from the torque.
Post Posted: Wed Feb 03, 2010 7:53 pm
wev'e been through this the flywheel weight makes fuckall difference to how much power your engine can make
you need the flywheel that matches your gearbox, 18 spline is flat so gti might work with that cause its the same clutch as a swift but I doubt it
20 spline is stepped so wont work at all
Post Posted: Fri Feb 05, 2010 7:35 pm
So you dont think it will work, What do you mean by stepped cause ive machined my gti Flywheel for it to be a "lighten flywheel"
Its sitting in my gti out back so if it can fit ill use it but if not ill sell it lol
And i know it wont make me power fitting it, but it will make the engine run with less strain being lighter then standard, TRUE ??
Post Posted: Fri Feb 05, 2010 7:51 pm
yes lighter flywheel is better for acceleration, not as good for smooth idle though
bit the common sierra box uses a flywheel that not flat it has a stepped section where the plate runs so the pressure plate wont work with a flat flywheel
Post Posted: Fri Feb 05, 2010 8:01 pm
Thanks royce
If some has a picture of a standard sierra Flywheel can they send it to me or post it up,
Cheers guys
Post Posted: Fri Feb 05, 2010 8:30 pm
89 sj50 WT flywheel with a broken bolt
Post Posted: Sat Sep 18, 2010 2:18 am
I have a 1.3 gearbox with 20 spline, do I need a flywheel that steps out where the clutch plates touch ? Cheers
My Maruti build, Click WWW
Post Posted: Sat Sep 18, 2010 2:29 am
erm, for what?
Stock sierra has a step in..
Vehicle: 4wd
Post Posted: Sat Sep 18, 2010 2:32 am
Use the 1.3 flywheel not the baleno one
Watch out or you'll get sued.
Post Posted: Sat Sep 18, 2010 3:08 am
I thought for a minute that Dak Dak Dave was back :lol: :lol:
Someone resurrected an old thread too, instead of starting a new one 8O 8O
Vehicle: Nissan
Post Posted: Sat Sep 18, 2010 3:14 am
x2 8O :lol:
Pearce-toff Racing
Post Posted: Mon Sep 20, 2010 8:53 am
WRONG
WRONG
no 1.3 sierra ever used a flat flywheel , i think you got duped (while we are on an old thread) also no 1.3 sierra ever used the same spline as a swift.
Post Posted: Mon Sep 20, 2010 9:14 am
I would just like to add....
This is a total load of shit.
The flywheel stores energy, and assists in smothing out the peaks and troughs of power output etc.
Even though v.w.dave is no longer here, perhaps we can change his name to fos.dave for all the misinformation provided.
Post Posted: Tue Dec 28, 2010 4:42 am
Though I'd keep flywheel stuff together.
I have a G16A block that was connected to an auto. I've gone to put the 1.3 flywheel on and it doesn't fit. :( As you can see it isn't flat. No timing pin either.
The collar appears to be the same size as the spigot bearing.
What do I do?
1. Grind the collar flat.
OR
2. Is there a smaller spigot bearing that goes inside the collar?
SS
Post Posted: Tue Dec 28, 2010 4:49 am
This thread always makes me laugh :lol: :lol:
That collar is where the spigot bearing lives. Is that engine out of a Vit?
Post Posted: Tue Dec 28, 2010 5:10 am
Glad it tickles you but I don't hang around this end of an engine often. :roll:
Baleno engine I think. :?
OK that will make it extremely small as the collar OD has the same OD as the 1.3 spigot bearing.
So to fix it, I knock out the bearing in the flywheel and source a 1.6 spigot bearing?
SS
Post Posted: Tue Dec 28, 2010 5:21 am
That sounds right.
Post Posted: Tue Dec 28, 2010 5:26 am
Thanks Scrawn. :P
SS
Post Posted: Tue Dec 28, 2010 6:07 am
That look's like an adapter for a toque converter, should tap off..
Post Posted: Tue Dec 28, 2010 6:14 am
I've given it at tap thinking the same that it could be a spacer thingy.
Maybe I need a bigger hammer. :twisted:
SS
Users browsing this forum: No registered users and 46 guests
