It is currently Tue Apr 21, 2026 7:42 pm
Vehicle: sierra 1992
Post Posted: Wed Mar 31, 2021 7:02 pm
Noob question.
Just go my 1992 Sierra project blue slipped and registered. All good. Very pleased with drive ability and new suspension etc.
But one small query. When decelerating in 3rd and 2nd can sometimes backfire in exhaust.
It’s timed well at 850rpm and 8 degrees off flywheel.
Does smell a little “fuelly” in exhaust. Could the carb being running a bit rich. Is so is there a mixture screw on the carb that can be adjusted leaner.
Thanks,
Matt
Vehicle: Suzuki sierras
Post Posted: Thu Apr 01, 2021 5:56 am
G'day I would check if the exhaust has a leaking gasket or a hole.
Cheers Jack jr
Post Posted: Thu Apr 01, 2021 8:00 am
Thanks
After further searching on the forum have realised that there is a blocked off mixture screw that is better off left alone.
Some suggestions about checking vacumn lines?
If air is getting into exhaust that would give enough O2 to allow combustion?
Thanks
Post Posted: Thu Apr 01, 2021 8:43 pm
Are you still running the factory wax / auto choke?? If so, odds are it's failing/failed =)
Post Posted: Fri Apr 02, 2021 12:22 am
Yes I assume so. Can it be removed?
Post Posted: Fri Apr 02, 2021 10:04 am
I'll fix it for you:
alien wrote:
Are you still running the factory wax / auto choke?? If so, odds are it requires adjustment =)
I can't stand the idea that people pull things off of carbs and therefore put up with progressively less functionality and more compromise because they failed to bother to find out how it works.
As much as I couldn't care less about carbs, they're not as complex as people think and they're not a magical box of hocus pocus.
Get a factory service manual, set the carb adjustments up as described and then, if something doesn't work follow the troubleshooting guide to fix it.
there's a perception that every carb needs "rebuilding" and this is false.
Generally, the idle jet gets blocked with debris from a failing fuel pump, and other than that, ignorant mechanics and owners have been in there "tuning" them by fiddling with every external adjustment, when, basically, they can't be tuned because there's no need, they just need to be setup as the factory intended.
Post Posted: Fri Apr 02, 2021 2:45 pm
But those wax chokes do fail and get stuck running rich.
Users browsing this forum: No registered users and 71 guests
