It is currently Sat May 02, 2026 4:04 pm
Vehicle: 1991 Vitara SWB
Post Posted: Sun Jul 07, 2013 1:41 pm
Ok, did a search and it looks like I need
Falcon alternator from EL, the Mitsubishi none, not the Bosch.
1.3 Sierra alternator bracket
Dayco 3PK0840 840mm multi V belt
Am I forgetting anything?
Also how do I attach the wires from my existing alternator set up onto the Falcon alternator?
Much appreciate any help.
Cam
Post Posted: Sun Jul 07, 2013 1:45 pm
Did you have a read thru here? viewtopic.php?f=17&t=5529
It should have everything you need to know in there
Post Posted: Sun Jul 07, 2013 2:37 pm
Thanks, So it seems I need to get the Falcon wiring too.
I'm guessing this will have the 70 amp fusable link which is needed?
But I'm still wondering about how to attach the Vitara wiring to the Falcon stuff..
Anyone done it got any pics or details?
Thanks
Post Posted: Sun Jul 07, 2013 4:06 pm
Thanks
All in here.
Vehicle: 93 Vitara -itty bitty lift
Post Posted: Sun Jul 07, 2013 7:40 pm
bogfrog wrote:
connect alternator wiring up. Now as mine was orig a 1ltr engine and still has all 1Ltr wiring I had to work out what wires went where? I worked it out eventually just had to make sure she was charging and all lights on dash worked properly. Here's what I did: Delete the Black wire fold it back and tape back, then connect the white/green wire to the top pin on Alt then the white/Black one to the bottom pin then just connect charge wire and she's all done! You will have to work out this end for yourselves as my wiring colors will be different unless you have an 83' ish SJ410 as well?
I dont know what the black wire is, dummy load would be my guess but its just a guess
Post Posted: Tue Jul 09, 2013 12:57 pm
Ah thanks mate.
Last question guys... I just rang the wreckers asking for a sierra1.3 alternator bracket and he asked me which one I wanted, top or bottom....
I'm guessing it's the top one I want?
Post Posted: Tue Jul 09, 2013 1:17 pm
why don't you just mod the vitara bracket? (viewtopic.php?f=4&t=13839&p=667506&hilit=alternator#p667506)
If you do get the sierra one its the bottom one you need, the top is just a slotted bar to set the belt tension, vitara should be the same
Post Posted: Tue Jul 09, 2013 3:28 pm
Awesome link mate. That's perfect.
Thanks !!
Vehicle: '94 suzuki maruti
Post Posted: Wed Jul 10, 2013 7:59 pm
for the plug, i just used crimp terminals. been in there for 18 months and hasnt fallen out once yet. you do kinda need to put them in before putting the alternator on the bracket as its in an awkward spot but I havent had a drama with it despite it being dodgy
Users browsing this forum: No registered users and 16 guests
