It is currently Sat Apr 18, 2026 8:48 pm
Post new topic Reply to topic  [ 59 posts ]  Go to page Previous  1, 2
Vehicle: sierra
Post Posted: Fri Feb 17, 2012 9:45 am
well let us know 8)
Post Posted: Wed Feb 22, 2012 7:53 am
I've done the same thing in a plastic tub. As ball said, I used washing soda too, and mild steel anode. I was thinking of bolting the anodes around the side of the tub, apparantly this is preferable if you're anodising but I don't think it matters much if you'er just going to be killing rust.
Oh, and I run mine outside. As ball said, a shed full of hydrogen would be interesting :twisted:
Vehicle: sierra
Post Posted: Sat Feb 25, 2012 9:47 pm
how did it go?
Post Posted: Wed Feb 29, 2012 7:56 pm
Wouldn't a tub full of molasses be cheaper and easier?
That shit eats rust like you wouldn't believe!
Vehicle: 91 Vitara SWB
Post Posted: Sat Mar 03, 2012 4:05 am
My old man uses molasses all the time to remove rust for his tractor restorations great stuff
A brave man may not live for long but a careful ma
Post Posted: Sat Mar 03, 2012 4:26 am
I don't know about cheaper.
The washing soda was about $5 from memory and I only used about 1/10 of the bag.
Molasses stinks and I have heard if you leave the parts in too long they get eaten.
Post Posted: Sat Mar 03, 2012 11:27 am
There are a few sugar refineries around Qld so I can get molasses cheap or free.
Molasses does not eat iron, only ferric oxide (rust).
Post Posted: Sat Mar 03, 2012 12:12 pm
thats why horses don't rust.
Post Posted: Sat Mar 03, 2012 1:23 pm
Josh, it wasnt funny the first time
Post Posted: Sun Mar 04, 2012 6:08 pm
would any brass that is firmly attached to a lump of horribly rusty steel be affected by molasses de-rusting?
I have a little project I would like to clean up- but cant remove the brass from the steel- and dont know if the acid effect on the steel would chew out the brass as well?
any industrial chemists around that could figure it out?
stephen
Post Posted: Sun Mar 04, 2012 7:31 pm
according to this: http://users.eastlink.ca/~pspencer/nsae ... lysis.html
brass is OK?
Vehicle: 89 vitara
Post Posted: Sun Mar 11, 2012 2:36 pm
this is the same procedure to do cooper coating
Vehicle: Vitara/LWB "ZOOKINI"
Post Posted: Wed Mar 21, 2012 5:27 pm
8O Reading this one made me stress about homework again. Not a pleasant feeling, as I rarely had completed it.
Interesting to see how this will come up, Reminds me of a coin in a glass of coke.
Anyway thought I would chip in.
Vitara= Awesome
Post Posted: Sat Mar 24, 2012 3:36 pm
Anymore happen on this?
I have a spun steel camp oven thats sat outside for ages and is rusty on the outside now, I know it wont matter to the oven but I might try and clean it up with this
Can I just hook it to a big battery or do I need to limit the current?
Post Posted: Sat Mar 24, 2012 6:59 pm
I used a car battery with speaker wire, nail, baking soda (should of used washing powder) plus item, it worked to an extent my item was too far gone, but i think what you use as a electrolyte and amount and also voltage the sites i looked up recommend 6 volts. Current i think is more for plating or at least i know for brush cading.
Here's the sites
http://web.archive.org/web/200708191527 ... crust.html
http://www.instructables.com/id/Electro ... aka-Magic/
Post Posted: Sat Mar 24, 2012 7:53 pm
I tried a couple of different items with quite mixed results.
Most engine parts that were cast iron cleaned up fine.
I tried a handle of a lathe I am about to start restoring but instead of cleaning it up it just turned black.
Haven't had time to go and research what the material was and why it changed colours.
Vehicle: sierra
Post Posted: Sat Mar 24, 2012 8:29 pm
can we have an after pic? i think it would depend on the types of metal you used as to why it turned it black..... was it the brass that turned black?
Post Posted: Sat Mar 24, 2012 8:43 pm
This might something to think about as well.
Hydrogen Embrittlement of Steel - A Cautionary Note
Atoms of hydrogen absorbed by steel are known to enter the lattice of iron atoms and prevent the layers from sliding past each other easily. This causes the steel to become more brittle and liable to crack. The absorption of hydrogen by steel is a familiar problem in industry which arises during steel refining, heat treatment, acid pickling or electro-plating. It can also happen as a result of simple corrosion. The standard remedy is to bake the objects in ovens to drive out the absorbed hydrogen (200°C for four hours would be a typical regime in industry). The simple passage of time is also known to cause loss of hydrogen from steel. Hydrogen embrittlement may occur to some extent during electrolytic de-rusting. This may be a cause for concern with saws or other edge tools. It might be wise to wait a while before setting saw teeth after prolonged, electrolytic de-rusting. Alternatively, baking the tool in the oven for hour or so at about 150°C (300° F) should remove absorbed hydrogen. Note that this baking temperatures is low enough to leave the temper of most steels unaffected. Since hydrogen embrittlement is reversible, it should not cause too much anxiety. I believe that the advantages offered by electrolytic de-rusting justify wider experimentation by tool collectors. As more experience is gained clearer knowledge of its advantages and disadvantages will emerge.
Ball, the black surface could be black oxide which has anti corrosive properties and if you don't like it, it can be scrubbed off with a wire brush.
Post Posted: Sat Mar 24, 2012 10:03 pm
No brass on it
The surface looked exactly like it was black oxide. Save me chemically treating it if it is. :wink:
Post Posted: Sun Mar 25, 2012 11:45 am
A pinion makes a great anode :)
bubbling away now at about 2 amps, if you move the anode around you can set teh current to suit whatever is supplying it
In a closed garage, I dont smoke so it will be fine :)
Post Posted: Sun Mar 25, 2012 9:31 pm
1 campoven sorted and another in the tub, nobody has exploded yet either
Post Posted: Sun Mar 25, 2012 11:39 pm
is your camera broken, I don't see any pics :(
Post Posted: Sun Mar 25, 2012 11:40 pm
the flash might set it off =)
Post Posted: Mon Mar 26, 2012 3:45 pm
Exactly :)
Here is an early start on a lid, did a great job in no time on it, I started doing the bottom part on its side in sections but decided it was easier to fill it with the liquid and dangle the anode in the middle, worked really well and got it all clean and loose enough to brush off with a little scrubbing.
Ive had a cast one going for almsot 24 hours now so ill get some pics of that, though it slows down really quickly cause the anode gets coated and you have to keep cleaning it all off every few hours, ive jsut let it run itself
Vehicle: sierra
Post Posted: Mon Mar 26, 2012 7:39 pm
very nice!
Post Posted: Mon Mar 26, 2012 8:41 pm
Some more, this was a cast iron pot that was really bad, I reckon I would of chucked it
and a trivet thats going now
Vehicle: sierra
Post Posted: Sun Apr 01, 2012 6:02 pm
that cleaned it out really quick
Vehicle: Daisy
Post Posted: Thu Apr 19, 2012 10:06 pm
For any of you playing around with this, don't go hooking it up to anything over 120V DC as you get out of the Extra Low Voltage range and you're playing in territory that requires you to be an electrician. You can also get hurt. You shouldn't need that much voltage anyway :p
Back to the science, this stuff is ridiculously cool, good to see you guys using it!
Users browsing this forum: No registered users and 25 guests
