It is currently Thu Apr 23, 2026 11:52 pm
Post Posted: Sat May 14, 2011 10:08 am
Got the Tough Dog 80mm lift kit fitted with extended brake lines and now the ABS light is continually on. Brakes still seem fine (although haven't tested ABS). Got it booked in soon to have them check it out. Hopefully not a big deal. Any clues what was done incorrectly ?
The lift certainly is feels high compared to the OME lift I had. Harder ride as well. Will be good when I get the larger tyres though. (about 3 week wait)
 Profile YIM
Post Posted: Sat May 14, 2011 10:12 am
Are the ABS sensor plugs all plugged in? (one on each wheel)
Post Posted: Sat May 14, 2011 10:25 am
IT stays that way unless your carrying weight 8O
Post Posted: Sat May 14, 2011 10:33 am
Are you suggesting he gets pregnant? 8O
Post Posted: Sat May 14, 2011 10:34 am
:rofl: :rofl: :rofl:
Post Posted: Sat May 14, 2011 10:35 am
Ummm...I don't know.
I'll have a look at each wheel (Tomorrow...I'ts bloody freezing at the moment)...(Is it just a cable connecting them ?)
Thanks
 Profile YIM
Post Posted: Sat May 14, 2011 10:36 am
Thanks
Will be an electrical plug.
Post Posted: Sat May 14, 2011 10:37 am
Thanks
Cheers.
 Profile YIM
A mechanic mate of mine told me that i may have to take it in(when i do mine) and get Suzuki to work there magic with the computer stuff.
Post Posted: Sat May 14, 2011 10:45 am
It's not adjustable......... so what "magic" are they going to work???
OP, you have either stretched a sensor wire or one is disconnected...
ABS should not be fucked with!!!!!!!!!!!!!!!!!!!
Post Posted: Sat May 14, 2011 10:46 am
Fark knows.
Post Posted: Sat May 14, 2011 10:55 am
Fark knows.
So what knowledge do you have on a modern day ABS system???
How does it operate???
Post Posted: Sat May 14, 2011 10:59 am
Fark knows.
Smoke and mirrors. :wink:
Post Posted: Sat May 14, 2011 11:09 am
Not even close...................
:roll:
Post Posted: Sat May 14, 2011 11:14 am
Fark knows.
Well der, when you lift it the diffs rotate and upsets the ABS ecu cause it thinks you are going both uphill and downhill at the same time and the reverse circle spin ratio gets all screwed up.
Post Posted: Sat May 14, 2011 11:18 am
Fark knows.
IT starts at the peddle. :blink: and the end result is the car stopping :roll:
Post Posted: Sat May 14, 2011 11:36 am
Fark knows.
:helloo: Bingo!!!!
Post Posted: Sat May 14, 2011 11:39 am
:roll:
:helloo:
Post Posted: Sat May 14, 2011 11:40 am
:( well i hope the car stops
Vehicle: SJ50 hardtop!
Post Posted: Sat May 14, 2011 12:06 pm
Know any mechanics with a scanner tool so you can find out exactly what code is being thrown??
Or will it just be a general ABS code?? Hmm
NT SJ50
Post Posted: Sat May 14, 2011 7:15 pm
I'm returning to Brakeland... all they do are breaks. The 4X4 shop sent the vehicle there to do the break part of things. So hopefully they know what they are doing. They have been in business for years.
 Profile YIM
Post Posted: Sat May 14, 2011 10:00 pm
Stekky might know, the ABS might have a correct reset or bleed procedure otherwise the light comes on
I would think a brake shop that allows a car to leave with the light on is going to be useless in fixing it
Post Posted: Sun May 15, 2011 2:45 am
they must have disconected something accidently, because abs lines are easy to change, we do them often at work, so a sensor muct have come off or something along those lines
dodgy brothers mechanical
Post Posted: Sun May 15, 2011 2:48 am
So you can help me do mine then?
Post Posted: Sun May 15, 2011 2:54 am
its pretty simple even u could do them
Post Posted: Sun May 15, 2011 3:12 am
Either you have a left an abs connector loose, or you have broken the tiny little wires that ABS cables are. Time to get the multimetre out and find out where it is :P
helloo
Users browsing this forum: No registered users and 115 guests
