It is currently Sat Apr 18, 2026 5:47 pm
Post Posted: Sun Aug 07, 2011 2:38 pm
Good Evening AZ Crew.
:helloo: Welcome to DIY Vitara Power Window Switch Fix
Here is how I went about fixing the dodgy drivers side power window switch in my Vitara. Firstly remove door trim & remove Window Switch. The drivers side switch would not wind down the passenger side window, but it would wind it up. :twisted:
Parts Required:
Small Flat Blade Jeweller Screw drivers
Paper towel
Time taken with pics: 20mins.
Switch
Pop the clips & gently pry it open, there are 3 layers to the switch
sand
SAND
gently pop the window lock button off.
then separate the top off the board
this is the passenger rocker switch
and the illuminated drivers rocker swtich
pop off the rocker
lift out the contact springs
Showing the dirty contacts 8O
Now use a small piece of paper towel & the screw driver to clean the whole lot up, I scratched up the contact areas so they were all fresh metal.
clean up the spingy things
put the springs back in
put the rocker back in
grab you brothers toothbrush & some warm water & clean up all the buttons & platics.
line the tabs up for the central locking rocker
clip it all back together
Go outside & test.
All fixed... :wink:
Vehicle: JB420, APK416, A6G415, A6N415
Post Posted: Sun Aug 07, 2011 6:10 pm
:goodjob: :goodjob:
Most of the power window problems I've seen have been dirty or burned contacts, a quick clean like you did will fix the problem for a year or so, what I've taken to doing is using a very small cupstyle wirebrush in a rotary tool to really polish away the last scrap of carbon from the contacts.
Vehicle: GUII,35"tyres,5"lift
Post Posted: Sun Aug 07, 2011 11:43 pm
Nice write up ... inspired me to have a second go at mine this weekend. I have similar gremlins in mine :)
Thanks
PanterA ... Forever Stronger Than All
Pics: http://bit.ly/mmy6sX
Post Posted: Mon Aug 08, 2011 12:25 am
fordem wrote:
:goodjob: :goodjob:
Now why didn't I think of that... I even have a rotary tool in the garage. I did give the little rocker contact springs a bit of a tweak so they were sitting flat on the contact when depressed.
Thanks
It came apart surprisingly easy, I had the door trims off to tint the windows so I thought it was a good time to have a look at the switch.
Post Posted: Mon Aug 08, 2011 2:50 am
Good job Gus :D much cheaper then buying a new one from Suzuki 8O
Post Posted: Mon Aug 08, 2011 3:16 am
funny you say that, that was a brand new genuine switch 6 years ago. the original one failed in a similar way just after i got it & was replaced under warranty, it was fitted by suzuki & was well over $350 from memory.
Post Posted: Tue Aug 09, 2011 11:51 am
what you've done might stretch its life out by another 6 months or so... if ya lucky, those window switches allways fawk up at the worst time. I'd say, can the whole lot and fix it up with something better, like some carling contura rockers 8)
http://order.waytekwire.com/productdeta ... ODY%2012V/
Go Hard, Trailer Home
Post Posted: Tue Aug 09, 2011 11:58 am
i'll let you know how i get on. the switch is only 6 years old & was literally full of crap, but lucky for me... my alarm over rides the window switches so if a switch does fail with the windows down i just arm my alarm & the windows will still wind up.
Post Posted: Tue Aug 09, 2011 12:00 pm
ooer, you do have a fancy princess
Post Posted: Tue Aug 09, 2011 12:38 pm
Imagine how much sand is in my drivers side 8O :lol:
Post Posted: Tue Aug 09, 2011 12:55 pm
you should come down to beachport & give talkalottodd a taste of his own medicine.
Post Posted: Tue Aug 09, 2011 1:18 pm
Should i talk him to death :lol:
Post Posted: Sat Oct 20, 2012 6:22 pm
Armsup thanks for the write up, fixed my drivers side switch today that failed down at beachport... was the LHS that failed.
Vehicle: 2002 Suzuki XL7
Post Posted: Thu Oct 25, 2012 8:50 am
have to do this with my central locking switch, can open but not lock the doors when in the car, its stupid as its the most unused switch.
Car use to have a mind of its own when driving it would keep locking the doors, or if unlock it would play games with you and before you can get in will lock itself again.
I know the rear passengers window switch aint working, goes up but not down. Even second had there selling for around $75 and not guaranteed if there working or not. So looks like ill be cleaning mine :)
Post Posted: Thu Oct 25, 2012 9:04 am
If you have no luck just get a brand new aftermarket jobby from the switchdoctor on ebay mate. Cheap as chips and they look identical.
Post Posted: Thu Oct 25, 2012 9:05 am
my front passenger window stopped working on the new wagon, pulled & cleaned the switch as per above & it still didn't work, cleaned all of them in the master switch on the drivers side & it fixed it.
Post Posted: Thu Oct 25, 2012 9:52 am
Thanks Ninja,
I think if do a bit of beach drivng, salt gets in the switch and overtime short out the contacts, think that is exactly what happened to my central locking switch
Someone should make nice thin silicon seals/covers for them.
Vehicle: Ford Maverick 4.2 Diesel
Post Posted: Thu Oct 25, 2012 5:05 pm
power window mugs!!!!!!!!! good write up gus!!!!! reminds me never to buy a car with electric windows!!!!!! baha
Post Posted: Fri Oct 26, 2012 9:26 pm
try finding a car these days that doesnt have them :roll:
Post Posted: Sat Dec 29, 2012 2:50 pm
Just did this again in the new car - windows would go down but not up:
Before:
Bit of contact cleaner and a bit of scratching around with a screwdriver covered in paper towel later:
Whole switch was covered in dust and crap. I don't think my door seals are working all that well any more...
Post Posted: Mon Mar 10, 2014 11:26 am
Just opened up my drivers side switch and gave it a tickle up with contact cleaner! Hoorah much success, now I can operate the rear windows from the drivers side.
Mine actually didnt have much dirt in there just the contacts for the rear were dirty.
Post Posted: Fri May 23, 2014 6:50 pm
I was stuck half way to work with a storm on its way and a driver's side window that went all the way down and refused to come back up. Argh!
After pulling it apart, the switch block on my zook is very corroded and unrepairable but this got me to where I could pull apart the whole module and carefully click the switch pins to make the window come back up. So thanks for the instructions and pics.
Now I'm waiting on DHL to ship me my new replacement part from eBay China (where else? :) )
Vehicle: 1991 swb vitara JLX
Post Posted: Sun Oct 19, 2014 6:50 pm
ORDERED MINE OFF ebay aust SELLER 20 bucks odered it wed night got it friday lunch time
Vehicle: 93 Vitara swb, 06 GV V6 wagon
Post Posted: Sun Dec 27, 2015 7:18 pm
To clean the contacts properly order a fibre pencil off ebay
Vehicle: 1997 Vit SWB j20a
Post Posted: Wed Apr 11, 2018 9:31 pm
Great write up. Got my switches working again! Cheers!
Post Posted: Thu Apr 12, 2018 11:10 am
Word Armsup
Users browsing this forum: No registered users and 9 guests
