| Author |
Message |
johnray
Joined: Thu Jan 28, 2010 10:30 pm Posts: 28 Location: perth
 Posted: Thu Apr 28, 2011 1:40 am |
ok guys, changed my rear shocks last night as the original were knackered and now im considering changing the front does anybody know what the procedure entails. I'm keeping the original springs as its mainly a shopping cart that gets to go fishing up at Carnarvon once a year. I've got a set of jack stands and heaps of hand tools etc. Thanks Ray
DarkHorse
 Posted: Thu Apr 28, 2011 2:24 am |
Back off top nut (accessible from under bonnet) jack front up, stands in, remove wheels, remove bottom bolts (2, behind wheel hub) remove top nuts, pull/hammer like fark to get seized strut out of top mount.
royce
 Posted: Thu Apr 28, 2011 2:31 am |
no
jack up, stands under chassis
wheels off
jack under the bottom wishbone on the side you wish to work on and jsut take the pressure up, no need to lift the car
undo brake line retaining clip on strut
undo top strut mount (dont slide out jsut yet)
undo 2 lower strut mounts, pry strut from hub, hub will flop around but thats ok
pull down on strut to free top mount (use force if its a bit stuck, wont matter if you hurt the old strut)
refit is reverse
alexvitara
Joined: Sat Mar 26, 2011 8:45 am Posts: 1602 Location: Gold Coast
 Posted: Thu Apr 28, 2011 3:18 am |
what royce said, very easy
johnray
 Posted: Thu Apr 28, 2011 8:02 am |
thanks sounds straight forward, ill attempt soon
buzbox
Joined: Thu Jul 16, 2009 11:30 pm Posts: 3600 Location: Wollongong NSW
Vehicle: LWB Sierra & XL7
 Posted: Thu Apr 28, 2011 8:29 am |
I was going to do a write up when I replaced mine the other week but It's that easy I didn't think it would need one, It's pretty much as royce describes and very straight forward.
Besides the brake retaining clip, It's just 3 bolts. If you have camber bolts, don't forget which hole they came out of. The use of a rattle gun to get the top strut nut off is very handy. Mine were a bit tricky to refit into the top strut mount but a little bit of grease inside the strut mount tube did wonders.
got_bar_work
Joined: Sat May 15, 2010 8:30 pm Posts: 2214 Location: Brisbane
 Posted: Fri Apr 29, 2011 8:28 am |
If the strut won't come out of the top take the 3 nuts off and take the top mount out on the strut still.
Let soak in diesel for 10 min and it should come off easy then
Try not to let the hub fall down and pull on the brake line to much. Helps if u have a second set of hands
buzbox
 Posted: Fri Apr 29, 2011 8:31 am |
got_bar_work wrote: If the strut won't come out of the top take the 3 nuts off and take the top mount out on the strut still.
That's way too much work, I just put a screw driver in and gave it a tap with a hammer
DarkHorse
 Posted: Fri Apr 29, 2011 8:55 am |
When I took my original struts out I ended up having to cut them out of the mounts (trashed one mount  ) no amount of 'persuasion', Inox, heat or anything else would budge them.
alexvitara
 Posted: Fri Apr 29, 2011 9:33 am |
DarkHorse wrote: When I took my original struts out I ended up having to cut them out of the mounts (trashed one mount  ) no amount of 'persuasion', Inox, heat or anything else would budge them.
the top mounts? or the bottom?
