| Author |
Message |
Che
Joined: Thu Mar 11, 2010 10:30 pm Posts: 2401 Location: Perth
Vehicle: LPG 1.6 Sierra
 Posted: Fri Mar 25, 2011 10:33 am |
I chucked a small tub of stop leak into the radiator to stop a slow leak through the thermostat gasket. Oily stuff and a heap of pellets.
Coolant now looks like shit after 24 hrs - frothy and oily, but the leak has stopped. Am I supposed to replace the coolant after using the stop leak, or do you just leave it as is?
Scrawny
Joined: Tue Jan 29, 2008 10:30 pm Posts: 10528 Location: Brissie
 Posted: Fri Mar 25, 2011 10:35 am |
Leave it.
Why use that stuff when you could just replace a $1 gasket??
Red89
Joined: Tue Jan 12, 2010 10:30 pm Posts: 2801 Location: Perth
 Posted: Fri Mar 25, 2011 10:44 am |
Or even better just use some pepper out of the kitchen cupboard
zooky08
Joined: Fri Nov 27, 2009 10:30 pm Posts: 3426 Location: imbil/gympie. qld
 Posted: Fri Mar 25, 2011 10:47 am |
Or a egg
_________________ 03 Jimny 30 km2s 75mm lift f&r locked winch
Che
 Posted: Fri Mar 25, 2011 11:36 am |
I replaced the thermostat months ago - gasket was an easy job and razor bladed both surfaces clean. Random leak popped up about a month after the fix.
Just giving it a try - like you say a gasket is an easy enough fix, but you lose a heap of coolant getting the hose off. Got no spare gaskets or jiuce lying around so giving it a try to see if actually works
Lockie666
Joined: Sat Apr 17, 2010 11:30 pm Posts: 1874 Location: Perth
 Posted: Fri Mar 25, 2011 12:12 pm |
I wonder how that stuff reacts with the metal from the motor?
_________________ helloo
alien
Joined: Wed Mar 24, 2010 10:30 pm Posts: 16343 Location: Perth
 Posted: Fri Mar 25, 2011 12:18 pm |
im pretty sure it leaves a fine film inside all the hoses and the engine and takes AGES to get rid of (lots of flushing out).
i dunno dude - given you're about to embark on a huge journey i'd have tried a new gasket first.
Che
 Posted: Sat Mar 26, 2011 1:14 am |
Ha ha, how did I get two posts happening? Forum in stereo
buzbox
Joined: Thu Jul 16, 2009 11:30 pm Posts: 3600 Location: Wollongong NSW
Vehicle: LWB Sierra & XL7
 Posted: Sat Mar 26, 2011 1:48 am |
I put a bit of gasket silicon on both sides of the gasket, Sure it's a bit overkill, but that's how it was when I removed it and I know for sure it won't leak.
