It is currently Tue Apr 21, 2026 6:33 pm
Post new topic Reply to topic  [ 53 posts ]  Go to page 1, 2  Next
Post Posted: Mon Jul 14, 2008 10:35 pm
So I wanted somewhere else to put some spotties on my car. I fabricated a quick light bar to go up there that could fit four spotlights.
This is the car with the rubber stops:
Rubber Stops gone:
Bar made:
The bar it is made out of is ¾ inch tube that has been hot dip galvanised. This will make sure that if any moisture gets inside (doubtful) it won’t be too much of a problem. 5mm plate was used to mount it to the car.
On the car and spotties on:
Close up of Spot light bar:
Cost me absolutely nothing had the spotties the steel was scrap coz you need like 800mm of tube and a tiny bit of flat steel and you can knock it together in under the day.
lesspostingmorewheeling
Post Posted: Mon Jul 14, 2008 11:05 pm
thats a good looking light bar, can you rest the bonnet on the light bar or would the bonnet hit the lights?
Post Posted: Mon Jul 14, 2008 11:23 pm
yeah the bonnet rests just on the bar i made sure of this by drilling the holes out right at the back of the mounting plates.
Post Posted: Mon Jul 14, 2008 11:29 pm
did you use those pre bent bits or did you bend it yourself?
Post Posted: Mon Jul 14, 2008 11:31 pm
nah for this one i bent the bits my self because i had pretested 3/4 inch pipe and knew that it could bend. but yeah it bent it and did all the welds myself
Hows the glare like at night on the front window?
My light bar reflects all the dust dirt etc...= bad while driving long distance.
Only good for slow technical stuff.
Post Posted: Mon Jul 14, 2008 11:32 pm
what if you made a little deflector under each light?
Post Posted: Mon Jul 14, 2008 11:34 pm
thats really the only reason i made it up was for the slow tech stuff and for looks. Not really sure if this happens yet only put the spotties up there the sarvo and havent yet wired them all up. Do you reckon i should swap the inside ones to the outside? or leave it how it is?
i thought about that too but ill see how it goes when it is all done first.
Post Posted: Mon Jul 14, 2008 11:37 pm
Yeah i was thinking of making some sort of covers for glare, but cbf :lol:
Looks are always good 8) Bling :lol:
Looks ok with the black surrounds on the outside. Kinda like mickey mouse ears :lol: Cute :lol:
Post Posted: Mon Jul 14, 2008 11:40 pm
thats right and when this thing looks standard in everyway but a bit of barwork im not going to take it off because of lack of use.
Post Posted: Tue Jul 15, 2008 9:07 pm
Nice work!
Thanks,
Chris
http://www.nbs4x4club.com
Post Posted: Tue Jul 15, 2008 9:41 pm
Go original and do the Kermit eyes thing... :roll:
Post Posted: Tue Jul 15, 2008 10:27 pm
has anyone else done something like this before? On another forum they were talking about the alternator. Just wondering if people have had trouble trying to run 4 or more spotties on a standard sierra alternator. What else would fit?
Post Posted: Tue Jul 15, 2008 11:08 pm
i have to spotties and thermo fan and when they are running woth the headlight with the car running they can be a bit dull
Post Posted: Wed Jul 16, 2008 12:25 am
Yes, you will definitely need an alternator upgrade. Easy to do from what I've seen and heaps has been written up about it. But if you have any more q's then don't be afraid to ask here, we won't bite your head off like some Outer's wankers!!
Post Posted: Wed Jul 16, 2008 12:28 am
have you ever heard of someone using an old ford alternator like pre crossflow old?
Post Posted: Wed Jul 16, 2008 12:41 am
Did they alternators or generators back then? :lol:
No I haven't, have you?
Post Posted: Wed Jul 16, 2008 12:46 am
i was talking to a guy today who said he used one and he didn't need to change the pulley on it,
could you just use 2 alternators?
Post Posted: Wed Jul 16, 2008 12:47 am
well maybe i will move this to tech (i think more people look there) but would anything fit? maybe a vitara or jimny?
Post Posted: Wed Jul 16, 2008 12:50 am
i've heard of people using gti swift and ef falcon ones but i'm not sure what modifications are required to fit them
Post Posted: Wed Jul 16, 2008 1:48 am
If you can find the threads that cover this you will find everything you need to know. I think it is the EL Falcon alternator.
Post Posted: Wed Jul 16, 2008 1:52 am
is there a thread about using 2 standard sierra alternators?
Post Posted: Wed Jul 16, 2008 2:29 am
I found these pretty good:
http://www.outerlimits4x4.com/phpBB2/vi ... hp?t=79826
http://www.outerlimits4x4.com/phpBB2/ft ... alternator
or just check them all out:
http://www.outerlimits4x4.com/phpBB2/se ... de=results
I've not heard about running 2 alternators. But even 2 Sierra alternators will only put out about 90amps compared to the Falcon's 110A. Not really worth it is it?
Post Posted: Wed Jul 16, 2008 2:38 am
thanks for the links
i didn't realise the standard alternator only put out 45A i thought they were 60A
i got the idea from seeing a sierra with a 12v and a 24v alternator
Post Posted: Wed Jul 16, 2008 2:59 am
thanks i read that over and bid on an alternator :) hopefully i can get it to fit
Post Posted: Wed Jul 16, 2008 5:14 pm
did you make sure its the 11oA not the 100A?
Post Posted: Wed Jul 16, 2008 11:17 pm
well no i didnt fortunately i got out bid and asked the guy what it is when he responds i will see if i will get it
Post Posted: Sun Nov 16, 2008 11:52 pm
that light bar looks GREAT!. but i'll have 2 get someone 2 make 1 4 me as i don't have the equipment. BUT, thats sitting in the bolts 4 the rubber stops. does it bounce @ all? are them nuts in the top of the window definately strong enough? if so I'll get someone 2 make me 1.
Post Posted: Mon Nov 17, 2008 1:56 am
well driving around on bumpy dirt roads for about 5 hours didnt hurt it and it has been on for about 3 months now with 4 spotties on all the time. It did vibrate a bit a idle so i cut out some pieces of thin rubber from clark rubber to put in behind the mounts to stop it from vibrating and since then it has been great. Easy as to make just make sure you either take the windscreen sorround off the car or dont weld on the car as slag burns glass....
Users browsing this forum: No registered users and 29 guests
